The SN1 can act as a power amp only, either via connecting to it’s AV input or to the 4 din power amp input (disconnect the plug for power amp in-pre amp out).
Which connection gives best SQ?
Is the AV connection not just a pass through? ie no volume control?
pass trough no volume/balance etc
I would expect the AV would be equal then.
