As above thanks
Soundiiz or Freeyourmusic
Thank you ![]()
Awesome!
It works! A couple things to note:
If you want to avoid joining Soundiiz, you have to limit your transfers to one at a time.
I lost some tracks from relatively obscure albums that Qobuz doesn’t have.
I lost some tracks from Tidal playlists with more than 200 tracks. I suppose I could have broken up the playlists in Tidal and reassembled them in Qobuz, but I didn’t lose all that many.
SongShift is good as well, I use it to bring playlists and daily mixes over from Spotify to Qobuz. Supports all the other services and does a good job.
@jegreenwood
I am currently on Tidal and just started a Tidal vs Qobuz comparison (Qobuz was a late arrival in Canada). When you say transfer one at a time is that one track, album or playlist?
1 playlist at a time with an apparent max of 200 tracks.
Thanks for that
