Birding Time, Your local and international patch…
x10 is probably max for a garden. x8 may be better for close work on small birds.
Thanks. I’m after an allrounder and will likely do more garden and woodland.
I’d probably stick x8 and a wide a field of view as possible for woodland. Coated lens and if you are going out and about in rain consider waterproof types. So many available now it just comes down to spec and price.
I use Opticron, designed in the UK, made in Japan. Good binoculars with excellent optics at a fair price.
Hawke and Celestron are other good value brands. The RSPB sell Hawke as their own brand.
Having said that I’m considering moving up to Zeiss Ultravid….
Agree that 8x42 would be best. Global Birdfair is coming up in July in Rutland. All the main makes will be there so you can see for yourself how they compare and your personal point of diminishing returns. Glastonbury for birders - just Google it.
I/we have 3 pairs, 8x42 and two 10x42.
My go to is Opticron 10x42, does it all from garden to Serengeti.
BirdFair is an excellent option if you can make it. Binoculars ideally need to be tried out as, a bit like HiFi, they are a personal choice and one which fits/appeals to one person may not suit another. Whether or not you wear glasses is a particular factor.
On the lens front, if the subject is birds, then I’d simply get the longest lens you can a) afford and b) can reasonably carry. Avoid silly min apertures of say f/11 as in an older APS-C camera it could get a bit too noisy when the light is less than perfect. Shutter speed is king for birds as they rarely stop moving. I’d be looking at least for 400mm at the long end for birds, even in the garden.
For my garden, in the range of 200 to 400mm.
For when I’m on nature reserves fairly static (ie in a hide) 500mm + extenders/teleconverters.
On a reserve if mobile, 100-400mm zoom, with extenders in my pockets
Under the canopy
Imgur
An Eastern Wood-Pewee enjoys the afternoon breeze which kept carrying him from shade to sunlight without a move
Sunny Side Up
Imgur
We definitely need some serious rain. The water is evaporating fast from the ponds making it like fishing from a barrel. The egrets and herons are not breaking any sweat to catch their dinner.
Mounted a bird feeder about 3 foot from my computer room window. Should have done this years ago. Little baby blue tit being fed by the parent. It hangs there vibrating its wings to get attention and fed. Thing is, once the parent flies off, the little chick feeds itself anyway from the feeder :rofl:
Only used 175mm lens to take this.
No pictures please!
Imgur
A humble Green Heron, the first one encountered this spring. For some reason, they tend to show up 4-6 weeks after the arrival of their larger brothers, the Blue Herons and the Great Egrets. He changed position just when I was passing by, otherwise I would have missed him.
Snow Bunting taken whilst at rest on the summit cairn of Cairn Gorm with my humble IPhone. Suprising how close one can get to the mountain birds of the Scottish Highlands.
OK guys, getting a bit fed up with greedy pigeons raiding and emptying my feeders. I want to feed the tits and sparrows around here, but they have no chance.
Can you advise suitable feeders or a specific type of food I should use ?
This type of thing? Works for us.
We use feeders with anti squirrel cages, see the Collywobbles pic above.
We have a lot of pigeons, even nesting in the garden, but all they do is walk around the ground in the feeder areas picking up the dropped seed.
We use a sun flower heart mix all year, plus peanuts and fat during winter.
The orange look
Imgur
It is only the second time that I get to encounter the illusive Black-crowned Night Heron, this time from a much closer range. The breeze kept swaying long grasses into the frame but eventually he climbed to a higher spot putting him in the clear.
A step in the right direction
Imgur
Recent trip to Thassos, Greece. Rather uninspiring for birders. But, there are lots of these…
