Question for the forum. I have a NAC 172XS which according to the Naim website should have aptX Bluetooth connectivity. I don’t usually use this function but thought I would try to connect the other day…unsuccessfully.
On a search through my settings I found that Bluetooth is not fitted to my unit. Anyone else have this issue?
Wonder why it’s not fitted
If you have an ealy 172 it may not have Bluetooth, as this was introduced to Naim streamers during its life cycle. Also you need to have a later firmware version, although if your 172 had Bluetooth it would probably have left the factory with the appropriate firmware, but maybe worth checking to be sure.
Thanks @ChrisSU, the firmware is fully up to date I just don’t have the module fitted it seems. Early models not having this functionality will explain it. Thank you
I can confirm that my 172 has neither Bluetooth, DAB or FM.
