Bluetooth Receiver for Tivoli Model Two?
Hello, can anyone recommend a good sound quality bluetooth receiver to use with a Tivoli Model Two stereo? The only catch is it needs to connect via 3.5 mm (mini-jack).
The Tivoli is an early model with only AM/FM/Aux inputs so trying to get it set up for streaming if it’s possible or makes sense. Ideally I can stream Qobuz from an iPhone to the Tivoli. I’m not using the stereo but would like to give it to a family member. Thanks in advance.
Very happy with the Logitech BT adapter that connects directly to the preamp.
iFi blue would be perfect for this.
I used to have one of these. Comes with a RCA to 3.5mm cable as well.
It worked very well.
DG…
My partner has the exact same receiver on her shop PA system, works very well with no fuss.
Thanks for the replies, gents. I’ll take a look at those options.
