Hi all is there any advantages to these on the end of a linn ittok arm cable,the 72 pre is fitted with them
Im using adaptors at the moment ,lp12 bits has a cable in for 50 pounds using bcn
Regards martin
Well… Naim recommended them… Back In The Day…
My Ittok has BNC plugs on it - fitted by my dealer many years ago. My 82 cam with BNC sockets - as did my 72 (both of them…).
I fitted BNC plugs to my Ittok arm cable after using the adapters. It felt very worthwhile to me afterwards. Moved on since then to Prefix but I would say get a good quality cable. Your LP12 is worth it.
Fitting proper 50 ohm BNC plugs to your Ittok cable will be a definite improvement over using the original RCAs with BNC adaptors.
