Hi - I have a HiLine 5Pin Din to 5pin Din connecting my NDX2 to my 282. The plastic connectors are deteriorating and cracking off at the end near the cable, both ends - the din ends are moving about badly. What can I do? Can Naim repair? Disappointed with the quality tbh. J
If you do a search of the forums, “broken hiline” will provide you a number of threads already on the subject as unfortunately its not an uncommon issue. Yes Naim can repair, contact you dealer/Naim.
Beat me to it.
Martin
For a 1k cable - disappointed. Ill send back to Naim - thanks for the heads up. J
Just can’t begin to say how much I’m biting my tongue over this. ![]()
Waiting for a pre-owned Super Lumina to arrive first. Then will get fixed to sell.
I had two – 5-5 and 4-5 – and sold them both. Good riddance.
