Does anyone connect a audio Streamer to Naim Dac V1 via USB. Could I do damage if I tried that. Cheers David
Hi,
Do you have Bryston BDP streamer? You can connect one of the BDP’s USB sockets to a DAC input and the BDP will recognise it. Once connected the V1 will be visible in the BDP Dashboard under Audio Devices section. Play something in the Bryston MPD and it will play through the V1.
Thanks. When my Bryston Pi arrives in a day or
Two I’ll give it a try.
