Has anyone experience of using a BT Complete Wi-Fi disc to provide a wired connection to a Melco server. If so, is it possible to use the Naim app to send files stored on the Melco to a Naim streamer with the Melco connected to the BT disc via the LAN port and to the Naim streamer via the Player port?
I don’t see why it wouldn’t work. I use the discs for WiFi and you can daisy chain them by WiFi or wires so worth a go
