I wonder if anyone has home built or is doing so an equipment stand?
Preferably one sensitive enough to accommodate a source namely a T.T.
or a CD player. But not solely limited to that criteria.
The last stand i imported a well known and reviewed brand that uses a LOT of Bamboo and Metal tubes with spikes. Was very carefully set up weighted up with some Amps and CD or
T.T. on the top i was greeted a penetrating upper presence band turned up to 10 and the Bass
what Bass??
So i set about thinking what can i construct i have no wood work gear as i am one of the mechanical persuasion and the only material i can get is from the local hardware.
So a simple garage design it is, Christ surely it is just a fancy shelf!
Experimenting with wood and acrylic i made 5 prototypes all on the mix match and see
what happens principal before i got a result i liked and use to day. Even some of the rejected
prototypes were still better than my Commercial Stand!
BUT THIS IS NOT ABOUT ME IT IS ABOUT YOU WHAT HAVE YOU GOT??
