have sellotape currently - sounds fooknn awesome.
Hi Richard, of course my post was somewhat tongue in cheek, as there was no chance of course that I wasnât going to have a tinker. As you can see from photo no point of touching and using 4 cable ties allowed me to achieve a fairly even distance between the two. Bit of a faff in this heat tbh. But was it worth it ( !? )after 17 years with my 552 with crossed cables throughout and no idea how that crept in.
Allowing the preamp a couple of hours after a 30 second shut down, I have to say the difference wasnât subtle. Always experienced a slightly emphasis of the upper frequencies on female vocals, something I attributed to my room- thatâs gone! There is a significant increase in resolution ( or maybe less noise) allowing better detail retrieval, separation and soundstage overall. To try and compare with a past upgrade, the magnitude of improvement was the same as fitting the sparkly bottom to my G3 distribution box.
THERE IS A HAPPY BUNNY MY END, and hey maybe a good reason for hanging out in this mad place, and goes to show that itâs never too late to pick up some free upgrades. Thanks again Peter
Also thank you to the OP for raising awareness re this.
Good news Peter. Told you, no snake oilâŚ,
