Probably not a broken wire, but just possibly a slightly dirty connection.
I suggest you turn off the power on the power supply the Burndy is connected to and then disconnect the Burndy and reconnect it fully half a dozen times at both ends. Now when you turn the power on it should be fine. If reasonably vigorous waggling of the Burndy causes any sort of problem, then you do have an issue that probably needs further investigation.
