Burndy question
I have looked on Naim website and tried to find out if :-
Does the the same XPS Burndy I use from XPS → NDX also work from XPS → NDX2 ?
Website states NDX but no mention of NDX2 as far as I can see ?
Yupp it does :+1:
@Slamdam Thank you so much for almost instant reply !!!
S-XPS Burndy cable is the fella.
Also works for XPS to CDX2… :crazy_face:
From another thread came this response from Richard Dane
“The original XPS Burndy was grey. There was then an improved version in black. Then during XPS2 production came a further improved version, also in black, called the S-XPS Burndy. The way to identify this last one is that it has S-XPS printed on the collar band.”
The ‘Search’ feature can be very helpful…
Thank you all for the help - what would I do without this forum ?
:thinking: Indeed… If you know how to use it…!!
