Posting on behalf of my friend, any issues in buying a 5 yr old nova,? And are. they the same spec as the latest model, thank you
It will be identical. Just 5 yrs older.
There have been no added features or changes in specifications of the Nova since it was released.
Given the huge supply chain problems that the electronics industry has faced over the last few years, it’s almost inevitable that some components will have been sourced from different suppliers over time, so I would expect there to be minor differences under the hood, but I don’t think this is something you need to worry about.
It should be fundamentally the same as a current unit.
