Presumably this isn’t anything to worry about? It’s a 2019 unit so not out of service. My XPSDR did the same, but if anything the 555 is louder and the buzzing can get quite loud. It’s intermittent and is most noticeable in the morning.
I’m not electrically minded but presumably this is interference from something else on the circuit? I’m planning to install a dedicated consumer unit in time if that’s likely to alleviate it. Anything else I could try?
Almost some dirty thing that is being used within your house and connected to your electrical supply.
Favourite things are fridge/ freezer, washing machine and a personal favourite of mine the hair dryer.
Thanks all. Will try and isolate the offending item and might just live with it until it’s on a dedicated circuit. As long as it’s not doing any damage to the PS!
It seems to be totally random with Naim products what hum and don’t. Not sure why it is like that. My 300DR PS is dead silent. My XPSDR hummed quite some. My 555PSDR is dead silent. My Supernait 1 hummed, my SN2 never did, my SN3 did, my 250DR did.
DC on the grid most often make toroid transformers go bit bananas and hum on the incoming side. This never translates to hum in the speaker so it’s a mechanical hum. However if there’s a lot the transformers get saturated and heat can start to build up meaning the transformer cannot perform at its full capacity. So a DC Blocker of like any kind will reduce/remove this. There are lots of discussions in this forum related to it so search around a bit. The DC is caused my something with a motor on your grid or LEDs, Dimmers and such. Heat pump, dishwasher, washing machine, fridge, radiators etc
I used to have a constant, audible hum on my power supplies and power amps. Not too loud but definitely audible. They also used to buzz loudly for a few minutes several times a day. I got used to it. Then I had a dedicated mains feed installed and the constant hum fell pretty much silent. I still get the loud buzzing several times a day.
I turned off the other consumer units in the house meaning that only my hifi had an electric supply. The buzzing several times a day still occurred. I am told it is most likely DC on the mains from outside my house, and therefore beyond my control.
I tend not to fret about things I cannot control, and the dedicated mains made such an improvement to my system, that I am a happy boy.
If the hum is caused by an electrical device in your home, a dedicated mains circuit from a separate consumer unit may well help. (Even if it doesn’t, it’s a worthwhile thing to do.)
If the source of the hum is outside your own house, dedicated mains won’t improve it, although I would recommend doing it anyway if you can.
Absolutely correct Chris. We do need to be careful not to dress dedicated mains up as some sort of panacea. If you live in a residential street with lots of neighbours all putting demands on the mains supply then even with “dedicated” mains feeding your hifi transformers will still hum. Possibly not as much but they still will.
Don’t worry, although annoying. This almost certainly is caused by the toroidal transformer saturating due to asymmetric mains or so called DC on the mains, which is not the same as dirty mains… as the mains can be clean but asymmetric. Large toroidal transfers are relatively efficient and therefore are more liable to saturate.
This is likely caused by an asymmetric load in your house or neighbours on the same phase as you. Washing machine heaters, dishwasher heaters, laser printers, hairdryers can be culprits.
If really annoying you can try a commercial mains DC blocker… or if you have old wiring in your house you may benefit from a separate radial for your Hi-Fi, but if you have newish wiring that is unlikely to help.
There are also mains isolators which are large transformers which can help as well… but these can end up buzzing instead of your Hi-Fi…
