I just added a dCS Rossini player to my system consisting of cds3/xps/klimax LP12 /552dr/250dr.
I just found out that if I have the cds3 and Rossini plugged at the same time, there is a buzzing sound from both the inputs. Once one of them is removed, the buzzing sound on the other is gone.
The LP12 input makes no difference whatsoever.
I tired connecting a grounding cable from to the 552 to a wall socket and this made the buzzing sound on the cds3 much less but the buzzing sound on the Rossini worse.
But… the good news is I cant hear the buzzing sound at my regular listening volume at my sitting position.
Do you know whether the DCS Rossini has the signal earth connected to mains earth internally? If so, you’ll need to lift it in either the Rossini or the CDS3. Naim can do this as part of a service at the factory.
Otherwise, it can sometimes be down to the interconnect. Are you using an RCA to DIN i/c on the Rossini? Have you tried an alternative to whatever you’re currently using?
I am using the din to din superlumina for the S3 and a AQ evergreen RCA to RCA for the Rossini.
I didnt actually notice the buzz until I swapped the evergreen for a DIY RCA to RCA and the buzz got much worse. Thats when i did some troubleshooting and then found out about the buzz.
I have a RCA to DIN lavender (regular DIN to DIN interconnect reterminated to RCA on the source side) interconnect lying around. I will try that but will require some shifting around.
Its bound to be a cable, as like you i have a rossini plus a turntable and 2 tape decks plugged into my 552 and all if fine.
I would try some rca out to din for the rossini as that is what i found worked best, as i also use the balance xlr out from the rossini direct to my headphone amp
The XPS is currently plugged into 1 of the 4 wall sockets in my dedicated spur.
The dCS is plugged into a wall socket on a separate electrical circuit.
