Morning folks just joined , looks
Ike there is lots of interesting post to read
Need help conecting a. Hi cap i just purchased ( 2011)
To my 140 power amp and 62 pre amp a photo or drawing would help
Many thanks
It’s the same as a 202 to HiCap, pictured. You’ll need a 5 pin SNAIC to connect the 5 pin DIN output on the 62 to the 5 pin DIN input on the HiCap, then use your existing 4 pin SNAIC to connect the HiCap to the 140. Easy!
Thank you
