But can be a bit thin. Beef gives a richer presentation. Same as silver and copper interconnects.
Outstanding negligence.
Bravo
Admittedly I am heavily comforted by the level of some systems doing so well in this thread. Onwardsā¦
Awesome use of terminal blocks to connect speaker cables - I salute you, Sir!
You sure thatās not actually meant for bored but still peckish Budgies?
Itās one of those situations where, you know, you measure perfectly for the surrounds and then realise you havenāt measured with quite enough allowance so you add a bit. Then you decide you want to reposition the avr so you add a bit more and then you think, hmm, Iād like to lower the rear surrounds on the wallā¦ so there are connector blocks in the trunking tooā¦
Unfortunately Iāve been sensible and bought another reel of cable to redo them in a higher gauge at some stage
Yes, definitely not a ātrueā messinest. (Yes Iāve just invented that word)
Some cracking lack of efforts here, really nice to see.
Over 200 posts on something so shyte!
Believe it or not the tv mess was only stripped down last monthā¦!!
Been there ā¦ done that!
The perspective on this makes me feel like Iām staring into an infinite void of ever increasing cable messinest.
Mmm. Nul points for the messinest Iām afraid. You do get a bonus for the paint cutting in, though.
No pictures of tidy stuff please. There are other threads for such insanity.
I think the issue is that youāre not defining messinest.
I mean, our 15 year old describes his room as tidy. Your excellent contribution to the English language, messinest, however, would be an excellent definition off our opinion on the matter.
A bar needs to be set. I suggest you select a picture to act as the point of reference. Henceforth that picture to be the minimum requirement for posting on this esteemed thread.
So that is after you neatened it! I expect that task took 2 mins max?
Impressive.
