After this is done,.we will compare these contacts with,among other things,.Oyaide’s best and second best contacts.
Before that,.I can’t give you an answer to your question.
But as I wrote before,.we have test-listened and the result seems very promising (see post No 326).
• This NCF-material,.often helps to make it a bit cleaner and clearer,with more details.
But in some music-systems it can also make the sound a little too sterile,if you understand what I mean.
Henryski,…Do you have any picture of this contact,.that you can put in here.?
We tried this new Swedish powercable below,.with red copper contacts,in a Cisco 2960 and a Spectral pre-amp.
There was a lot of “sound” but less music.
Here it is, this is the most basic model. Red copper built by ex furutec employees and made in Taiwan.
Dont know if the pic has pasted right.
Anyways VGVFM iec, the best id say at 35.00 uk pounds.
It looks beautifful in the flesh too although SQ very good, but dont think quite up to Oyaide standard although it is all copper and not brass like the basic model furutec and i would say its a lot better than the basic furutec too.
You can also get the euro 2 pin wall plugs which match too but they dont do a uk 3 pin wall plug which i wanted to buy.
They also do a newer model which has much wider entry point for thicker cables. Also gold plated, silver and pure silver one is available which is around 125.00 uk pounds, which i would like to buy but cant really justify spending so much on an iec even though i like hi fi some prices are just too much. Maybe if i win the lottery i will be the pure silver one with a Dh Labs red sonic silver cable and finish off with a rhodium 3 pin plug.
I can but dream eh!
This is Mr.Cableoholic’s new Entreq hifi-rack under assembly,.for dual-Cisco’s and dual-Linear Power Supply’s.
It will be interesting to hear what difference it will be,.I think the difference in soundquality will be great.
In addition,.dual Jorma Design Duality powercables,with Oyaide M1/F1 contacts are burn-in and ready to start being used in these LPS.
This can be really,really good .
