Calling All Active Speaker Users, Which XLR’s to Use?
I have no idea what if any differences there are between different XLR cables - I chose mine on the basis of being reasonably priced and very likely what was used in the studio mastering many of the the recordings I have. I have heard differences between unbalanced RCA cables, but feel that there is a lot of hyperbole around the descriptions of effects, with cables in the realm of fine tuning rather than major upgrade. Also any effect will depend on the specific items a cable is connecting, so very much a try and see scenario, something I can’t be bothered with if the sound is right for me to start with. Maybe one day when I have nothing better to do… I wish you well (I hesitate to say fun) with your choosing.
I use something ready made from a pro dealer.
Pete, I love your logic :blush:. I don’t disagree with your points but there is one big elephant in the room. “Recording engineers make the music we listen to on our HiFi systems”. Does that mean what we actually listen to is not high fidelity? I.e. we are some way enhancing the music that has been recorded buying expensive components and cables? I’m getting into a very contentious area here so I’ll bow out after tossing in the hand grenade. :joy:.
I think the Swedish word “Lagom” best summarises my views on most things. I’ll leave it at that.
Look at it like this. You want to reproduce whatever is on the recording as well as you can, using the best components and cables you can. Not to enhance, but to prevent further degradation.
ATC also does not recommend replacing the power cable… but the difference between cables is large.
@NigelB I use Tellurium Q Black II between my 332 and 40A’s, also use Tellurium Q Black II power cords.
The question is whether some cables degrade more or less than others, or whether the effect is tweaking of sound character by altering frequency balance, e.g. making the sound ‘brighter’ or ‘darker’, the latter people using to fine tune the sound to their taste or to help balance effects of the rest of the system and room. From my own hearing, of course limited, and much of what I’ve read, it is the latter.
Without a doubt some cables degrade more than others. Some cables maintain dynamics, timing and detail much better for instance, and have greater bandwidth than others do. As far as altering the frequency balance goes then some cables definitely do this too. To me this is just an incidental thing. Using cables as tone controls to correct for imbalances in system matching isn’t sensible. If you need to do that then you have a poorly matched system IMHO. Having said that different cables can have different frequency balances, ie, be darker or brighter, and even though it’s just incidental and not a primary consideration, it makes sense to avoid anything that you dislike or that won’t suit your system. I’ve always avoided QED cables for this reason, as they have a reputation for sounding bright and I dislke a bright sound. But if there was a bright sounding cable that was known to be vastly musically superior to anything else then I would probably still use it and just put up with the bright sound if it was so much more musically convincing.
Never understand these cable wars.
When I had Living Voice Tone Scouts with a border patrol 300B amp and Kondo M7 preamp I tried many different speaker cables and settled on B&Q £2 per metre copper cable as they all sounded the same to me.
I’ll see your hand grenade and raise a “IMHO what people hear between cables, especially power cables, is priced based expectational” :rofl:
Were you able to compare the Tellirium Q Black XLRs to anything else?
:scream:
I’ve never expected more expensive cables to sound better. On the contrary, I’ve always hoped that they won’t as it would save me money. Usually though the ones I’ve tried have unfortunately always sounded better.
My only comparison was to the supplied ATC cables, I also had Tellurium cables throughout my system for XLR, USB, ethernet and power,
How did the Tellurium XLRs compare to the ATC supplied XLRs, or is that tricky to isolate?
I might argue that competently designed balanced connection (ie including the electronics at both ends) engineers out the variability of unbalanced connections using plugs and sockets that were not designed for the purpose…
… but I’m not expecting the argument to fly on a hifi forum.
Anyway - the answer is always ‘it depends‘.
Politician’s answer.
Absolutely. Always hedge your bets. Never commit.
I’ve never used a balanced connection myself but as I understand it this is one of the reasons why they are often preferred to unbalanced, especially in professional applications, as they are much more robust in terms of being susceptible to EM interference with the signal. Still in my view the quality of the cable still has a huge bearing as there are important factors other than shielding that impact on performance.
Well that was 5 years ago and I can’t remember what I had for tea 5 days ago :laughing: From memory a bit more flesh on the bone, if that’s the right terminology. The manufacturer, and those that stick with supplied cables, will naturally be of the view they are sufficient, if I had to make the decision again I would replace the supplied cables.
Strangely enough my ATC journey may be coming to an end, I’m planning an upgrade and my room is too small for ATC SCM50ASL, I’m off out this morning to a couple of dealers listen to PMC Prophecy9, Audiovector Arrete R3 and Kudos 505. Plan is to add a NAP250 to my 332/300.
