Hello !
Cambridge cxn v2 xlr conector to naim 5si din ?
Has somebody done it?
but I want to do it with DUELUN cables.
I got them now rca to rca DUELUN just wondering I will get more from xlr to din.
Thanks in advance.
Victor
Hi Victor - Your limitation here is the single ended inputs on the 5si whether you go RCA or DIN so you won’t be able to use the balanced outputs from the CXN. I’d stick with what you have.
Thanks a lot…
