Using NDX 2 controlled through i-pad.
Paul W
No, it doesn’t work unfortunately unless you cast it from the BBC Sounds app. It does work for some stations including Radio Paradise, but not from the Beeb.
Another reason I went for an Innuos. Get to see it all and can do a search from there to find a track in your library or Qobuz. Ability to do the same in Tidal is coming soon.
