I am using the Naim app (iPhone) to stream. ND5XS2. When the last track is played it goes back to the first track. I am using Qobuz. I never set anything to repeat. What can I do? I am using SA.
You’ll probably find that the Oval icon with the arrow in it, to the right at the bottom of the screen is highlighted. This is the repeat play icon.
Tap it to turn it off.
The difference in brightness between off and on can be quite subtle.
The shuffle play icon is the other side and can be equally challenging to see the difference between off & on.
