Hi all,
I have the option of a 555ps but just realised I need to buy 2 burndy to fit my NDS.
At cerca 1000 for a set, can anyone tell me will they work if i eventually upgrade to a 333 streamer or would i need a different set?
Also, is there a name for the actual cables needed for nds/555ps?
I think thats No and Yes… unfortunately.
Expensive Options.
Might be some pre-loved if you look around and ask…?
Claus
April 16, 2024, 4:27pm
3
No old power supplies used on nc models requires special burndies. and of course back before the new webpage there was a link to the different combinations, but maybe in the faq section of the forum?
Claus
April 16, 2024, 4:29pm
4
so yes and no seems to be correct.
Naim Audio has created a range of cables to connect the new Classic range with earlier products.
See the tables below to find the number reference you need for your connection:
[COMPATIBILITY-CABLE-INFO_web-1]
Burndy
Lead Assembly, Burndy, XPS to New Classic - 19 Way Single to 12 Way and 23 Way Burndy Cable. 00-010-0241
Lead Assembly, Burndy, 555PS to New Classic, Digital - 19 Way Single to 23 Way Burndy Cable 00-010-0242
Lead Assembly, Burndy, 555PS to New Classic, Analogue - 19 Way …
