I’m updating my system at mo,
In the mean time,
Can I power only my nac92r with my flat cap,
And use the HC into nap 180
If you’re powering the NAC92R with a Flatcap then the HICAP is redundant. Likewise if you power the NAC92R with a HICAP then the Flatcap is redundant. The NAP180 does not need the power supply, only the NAC92R. Only the pre-out signal runs from the pre-amp’s power supply to the power amp. This ensures the signal ground and system ground are kept as close together as possible for best performance.
Ahhh got it, thank you
