Can I connect another amp to run another set of speakers/sub off my highcap,
I’m using at mo,
Socket 2 to amp
Socket 4 to preamp,
I have tried looking for a topic on this can’t find one,
Many thanks
Socket 3 is designed for this purpose. I think you’d normally use sockets 3 and 4 with a single stereo poweramp, you start with the socket closest to 4. Then use 2 for a second power amp.
E.g showing where sockets 2 and 3 are used:
That is what I thought, thank you,
