You could run a diagnostic cycle. Load a known perfect disc and switch on while pressing and holding play. This will put the player into a special soak mode. This defeats the error correction and any errors will be counted and shown in the display. You would expect very few with a perfect disc and a mech in good health. So if it counts errors quickly (will count up to 10 then stop) then it likely indicates an issue with the mechanism.
