Cd3.5
Hi
Dose the CD3.5 have a transport screw :thinking:
Yes 2 i believe if i remember right.
One was in the centre at the front and the other in the corner. Or it could be the back?
It’s been a long time since i had mine.
But you will see the holes under the unit, obviously don’t turn it upside down to look, slide it over the edge of a table, also dont forget to remove the puck.
Did you think of looking in the manual?
maybe lost after a few decades
But available online, which is where I found it.
super!
Were you able to find the complete manual (I assume it covers other CDPs)?
I’ve found an extract that covers the CD3.5 (pages 14-18) but not the complete manual.
I only looked for the 3.5 manual, to help the OP. But I’ve heard nothing from the OP and just get stupid comments from others, who’ve done diddly squat to help. Hey ho, that’s the Forum I guess.
I’ve tried to collect manuals for older kit that is still “out there” but not supported by Glasgow, Huntingdon or Salisbury……primarily coz there’s a lot of it in our house!
