Does the cd555 play SACD.?
No - unless they are dual-layer i.e. have a CD readable layer.
HDCD yes.
OK thanks for reply.
I wouldn’t get too hung up with SACD. I had one of the original Sony SACD 777ES machines - in fact I still have it. Surprisingly, it’s heavier and larger than my CD555. However, the CD555 wipes the floor when playing CD against SACD on the Sony. In fact feeding a Naim DAC via coax the CD from the Sony sounds better than non-DAC SACD playback.
Its my understanding that in the design of the CD555 nain rejected the SACD option. SACD is a relation of a video format and to incorporate it into the 555 would be a compromise rejected by them. It will play HDCD and Linn have issued some in this foemat.
As Geko says “not to got too hung up on this one”.
Just to add some balance to this topic.
If done correctly SACD is fantastic and does have a performance advantage, you just need to hear it done right, as with everything hifi
