Cd555
On behalf of a friend who is thinking of pressing go on a CD555, are they still supported including the laser?
A few months back Signals had one and they said there were no issues then.
I think the original idea was to have one or two spare mechs per machine but it it may well have been on a first come first second basis. Best check with Naim here.
You should check on lasers with Naim but note that Naim no longer recommend ‘servicing’ though they will repair. I was nervous about my CD555 becoming useless and moved to an ND555 with Core. I have greater peace of mind and the SQ is better (with one 555PS).
I had the laser replaced on mine quite recently. Like a number of products such as Superline, servicing is ‘out’ for this unit I think.
The basis for not servicing, was to avoid being at the mercy of your dealer’s courier. But my dealer says, that you can drop off and pick up at naim. So, if i had a delicate item, that’s what I’d do.
My comment is correct - see your quote from 2024! I think you have now conflated two separate issues - one is about safe shipping, the other is about Naim’s withdrawal of servicing for certain products, including the CD555.
Ah, so they no longer service the CD555.id forgotten that bit. I cannot remember their reasons, but I do remember the debacle involving the Superline.
Thank you guys.
While there’s no set service routine for it, I believe the CD555 can be repaired and still have its mech replaced - I recall a recent post confirming same.
Wow, If you imagine that the CD555 was introduced in 2006 …
Probably my post - it was back within the month (actually saw it in Servicing on the Forum Factory Visit) and I have to say - sounding as good as it has ever sounded if not better.
It was indeed!
