Hi All,
Can I connect my CD5si to my XS2 through the HC2?
And if so… is it recommended?
You can’t use a HICAP to power any part of a CD5Si.
You can, of course, use the HICAP on the NAIT XS2.
Thx.
So the green mark side of the DIN cable between CD and XS goes to the XS2… right?
The band goes closest to the source of the music, so in this case, closest to the CD player.
One last question if I may…
I understand the need not to configure the output-socket-selection as both but how can I harm the system if I keep both cables connected (DIN and RCA) but configure only one?
