On the off-chance, does anyone here use Tidal as a source for CDJ-3000s? I would like to avoid using a subscription service such as rekordbox if possible
Many thanks
Many thanks
It doesn’t answer your question but what is a CDJ-3000s ?
Do you want to use Tidal to stream music for a DJ set, or just to use at home? If the former it’s probably not legal.
It’s a home system
Can you not just use the NDX?
My wife likes to DJ. So no.
