CDs alongside vinyl and streaming: sound quality and experience discussion
Hi all,
I’ve just added an Audiolab 9000CDT transport to my system and I’d like to hear how others think about CDs as a physical format.
My system
  • Audiolab 9000CDT (transport)
  • Naim NSC 222 (streamer/preamp)
  • Naim NAP 250 (power amp)
  • Pro-Ject Debut Carbon (turntable)
  • Tidal for streaming
Why CD?
I love vinyl for making me slow down and listen to a whole album without skipping. But vinyl has become very expensive, and sometimes I want physical media that’s more convenient. CD seemed like a good middle ground.
1. CD collecting and album art
Vinyl clearly wins on artwork. A 12" sleeve is a different experience from a CD booklet, and standard jewel cases feel cheap and crack easily. For those of you who collect CDs:
  • Does the smaller format bother you, or have you come to appreciate it?
  • How do you display or store your collection?
2. Better packaging: plastic or card?
I’m considering upgrading what I have, and I see two routes:
  • Better jewel cases: thicker or higher-quality plastic replacements. Any brands you’d recommend (or avoid)?
  • Card/paper sleeves: I’ve found a few online suppliers who make digipak-style or gatefold sleeves you can move discs and booklets into. Has anyone done this? How does it hold up for protecting the discs, and does it feel worth the effort?
Recommendations for suppliers, especially ones that ship within Europe, would be very welcome.
3. Sound quality: CD vs hi-res streaming
My realistic expectation is that a CD through a good transport and a hi-res Tidal stream will sound essentially the same, since the data should be identical or better on the stream. So I’m not expecting a difference.
Still, I’m curious:
  • Has anyone heard a real difference between CD and streaming on a comparable system?
  • If you have, what do you attribute it to: mastering differences between the CD and the streamed version, the transport, the digital connection, or something else?
  • Any advice on getting the most out of the 9000CDT into the NSC 222 (coax vs optical, cables, settings)?
Looking forward to hearing your experiences. Thanks!
In our house, we regular play both CD’s and / or stream the same ripped CD from a server.
Often no or little difference, ( to be heard)
( Note : Obviously that result will differ depending on systems).
Where it gets interesting is if Qobuz has a HiRes version of the same recording.
BW
R
CD has allowed me to build a ‘physical’ library of music I couldn’t afford on vinyl. It remains the best bang for your buck. Does it sound better/worse? All I know is ripped to my Core and streamed via my NDX2 it sounds great. Searching the Core is far easier and more rewarding than searching Qobuz imo. The only reason I can see to change plastic CD cases is to save space. They look fine on wall racks. Just press play.
I have Tidal over Quboz, those are interchangeable at lossless audio level I think. Or ia there a reason for you mentioning Quboz?
I only mentioned Qobuz because it’s the subscription I have. I’ve never compared it with Tidal. My dealer has of course and they recommend/use Qobuz. I doubt there’s much if any difference in SQ on modest systems like mine.
I use a Mark Grant S/PDIF between Core and NDX2 just for information. It’s beautifully made and beautifully priced.
Hi @Steinwerck
I gave up on vinyl due to the cost and indifferent quality of the product.
I swapped over to cd play back at zero cost with trading in my vinyl play back system and my record collection.
I find cd replay as good as vinyl and just as " analogue".
I often purchase 4 second hand cds for £8, now try that with vinyl.
I have only compared the physical cd against a WAV copy of the same cd on my NAS, and I prefer the physical format.
I do not use a streaming service due to the cost.
I am not missing vinyl.
Okay this one has been discussed aplenty but here goes:
  • As the OP says CD is good value, pretty much indestructible and the only hiccup can be a dirty disc or laser failure.
But:
  • In my experience a FLAC rip on my Core through the NDX2/555 is more organic than even my CDS3.
  • However, locally ripped files also sound way better than Qobuz which I find too in your face, I was always looking to turn Qobuz down. And equally I’m hugely impressed by the sq from Muso Qb2 when fed by the Core.
The elephant in the room:
  • On even a budget end turntable a reasonable pressing will present the music in such a way no digital source can match, not necessarily better, this is subjective of course.
  • And listen to a high end turntable from the likes of Vertere, Linn etc and you’re in a different league entirely.
  • But vinyl is more labour intensive, and lacks the convenience.
The conclusion is that ultimately in purely sonic terms my vinyl wins and despite best intentions I keep buying new records. That begs the question, what if I was starting out now? Digital no doubt.
That’s a hugely significant point here.
At least for the “format wars” debate.
In our house, we have a huge investment in both CD’s ( maybe 1400+ ) and vinyl records ( maybe 500-600), which pre dates anything streaming.
If I was starting again, would probably buy the very best streaming front end that could be afforded and a Qobuz subscription.
My only caveat here.
It’s nice to collect something physical - it’s yours to keep - then curate your collection on a shelving or storage unit. Which is often a thing of beauty, by itself.
I suspect - for a lot of us - myself included - every CD and Vinyl record has a memory attached to it and so it becomes important.
BW
R
I no longer stream and after being abandoned by Naim have a decent Accuphase CD system for my many discs. CD,pre,integrated.
Accuphase build the whole of their enterprise around CD so I am happy with the sound. They engineer and build everything themselves.
I throw the Jewel cases away and pocket them like this..
Digipacks and Mosaic box sets are obviously left.
I have no filing system but just pick a random CD and play it.
The problems that Shhhh Brexit caused to Discogs purchasers has now been further disrupted by the vinyl retreat. It used to be full of bargains..
I was a Naim customer for many years.Stiil use plugs and Fraim.
I’ve over 500 LPs and over 1500 CDs from back in the day…..
A handful of LPs remain played very occasionally.
TIDAL FTW here….
What do you get for sleeves then? A cd sleeve and outer cover?
What a coincidence, I’m listening to Jessica Williams at the moment, one of the Live at Yoshi’s albums. We had over 1,000 LPs and over 2,000 CDs, which took up a lot of space. How we have none, instead we have over 4,000 albums on the NAS, a Qobuz Sublime subscription and, significantly, a lot more wall space. I don’t miss the CDs for a second, with their horrid plastic cases.
All, I can say is that to my ears, a CD or CD ripped to a USB hard disc sounds perfect on my mostly headphone based system. I do have a very good SPL Phonitor HP amp and a choice of cans. My favourite headphone right now is the Heddphone GT.
With digital, the clarity and absence of clicks and pops is pretty important, as defects are more annoying with headphones. Sometimes a good HP system can reveal too much, and recording defects pop up now and again like a distant cough, or on one live album, the hum from a bad electrical contact
I rip my CD purchases, as using an iPad with a streamer is very convenient. I like to have the physical CD’s for the sleeve notes and as a backup. My 1988 CD’s are still perfect.
I gave up on vinyl in 1985, as I was sick and tired of poor pressing quality. I still have my old LP’s, but I have not played an LP for thirty years.
This is the logical way to go, but I cannot give up the habit of digging out and hunting down physical CD’s.
And she will take us to the heart of the matter.
I have enough cds to last me for the rest of my days.
You will find a lot of Jessica’s earlier work on streaming channels but she then broke all ties with the music selling business and produced and sold all her CDs independently.
So if you wanted to follow her career to its conclusion you couldn’t manage it digitally.
That Maybeck is one of the best of the series. Pleased you are a fan.
I have no access so if her estate sold her music to a streamer this is wrong and I apologise.
Yup. Plastic pocket for CD in its paper cover with enough room in the pocket for front booklet and back cover.
I regularly listen to all three formats at home and recently brought a new Cyrus cdt XR it’s a marvelous bit of kit I was using a Oppo 205 previously and whilst you hope a dedicated transport is going to perform better the uplift in performance took me by surprise.
Streaming and CD playback are probably tied at around 40% each with Vinyl the last 20%
Here’s the thing,
Whilst I often relax of a evening listening to music using all formats.
I don’t think I’ve ever sat down of a evening with lights low a glass of wine or a wee dram in hand to listen to a cd or some streamed music…it’s always vinyl.
I finally abandoned vinyl for the better sound quality of CD about 17 years ago, having continued with vinyl alongside for many years before that. Four years or so later, triggered by demise of my CD player, I switched to streaming from my own local store (as opposed to online streaming). I found that better for multiple reasons: notably access to higher resolutions via download, reduced storage space, no maximum play time causing long albums to be split over multiple discs, and no longer faced with approx 10 year life of CD players before wear causes problems.
I have never regretted my change from CD to streaming, the only thing I would miss, so I kept the ones from my ripped CDs is the libretto booklets that commonly accompany opera CDs - sadly not available for downloaded opera. I don’t miss the fragile “jewel” cases, nor the CD insert with its tiny text. As for vinyl, the one thing I miss about vinyl is the physical sleeve, which with some albums was a thing of beauty, something to treasure, adding to the experience of playing certain albums, at least initially. Also with vinyl there was a certain “magic” to playing them, with the stylus lowering into the groove, the slight background noise of a perfect disc, maybe pre-echo of the first bars of music then it starts… but that is just nostalgia, and I prefer my music without that medium’s limitations.
And I almost invariably only play full albums, streaming not having tempted me to chop and change and play single tracks.
I listen to streaming, cd, vinyl and tape.
I enjoy listening to them all, but there is a difference.
CD and streaming I listen to how the music sounds. Vinyl, I just listen to the music.
Some people like listening to sound, (which is fine), I like listening to music. :slightly_smiling_face:
With my hifi system I normally listen to music, though I can use it to play sounds if I want by plugging in a different source instead of my streaming one…
