I have acquired a CDS3 but it does not have a remote - any idea what type I need and where I might acquire one?
The CDS3 originally came with a Narcom 2 or 3. Any Narcom will do fine though. You can also control it with a Flash, R-com, or i-com.
You can find older Narcoms on online auction sites , or else the Narcom 5 should be available to buy new from your local Naim dealer.
You are looking at around £70 pounds, I purchased one recently as new on a known site for my CD555, as I wanted to be able to select tracks using a number pad, for some reason not on the original CD555 remote.
