Dear all,
After many years of flawless operation, my CDX mk1 + XPS started skipping on every disc and sometimes it suddenly stops with “Err” on screen.
I replaced the laser pickup and, despite the occurrence of the skipping reduced dramatically, it is still skipping sometimes, an average of 2-3 times per disc and sometimes the same with “Err” on screen.
Aside of replacing the laser pickup I greased all the moving parts and slider of the transport with a special Electrolube electronic grease.
Which could investigate further in order to solve the problem?
I thought about:
- Replacing the magnetic CD clamp, despite grip looks OK
- Could be the problem related to the receiver IC SAA7376 and it should be replaced?
Thank you very much for your guidance
Daniele
