I am wanting to connect a CDX2 to a Uniti2 (and then later probably a Supernait 2). The CDX2 has DIN and RCA outputs. The Uniti2 has RCA inputs, and a different kind of DIN.
Does this mean that I should connect using RCA? Or are there adaptor cables for the DINs? Any sound quality difference?
Suggestions of specific suitable cables suitable for this setup are very welcome.
Use one of the RCA analog inputs
if your CD have RCA out just go buy a good RCA interconnect within budget.
otherwise you will need a DIN5/RCA2 interconnect.
