Hi @gthack
Thank you for this
Hi @Skeptikal @AndyR
I have an RCA to RCA from my bluetooth receiver to the input marked Tuner.
A RCA to DIN from my phono stage to the input marked CD.
A DIN to DIN from the NDS to the input marked Streamer.
And, not withstanding the different sources, I cannot honestly say I can notice a SQ difference between the the different types of interconnect terminations.
Hi @Hollow
I do not get any breakthrough, of any level, with all of my existing interconnects.
I conclude it is a fault with the loan Din-Din cable.
Thank you for your time in responding.
When I switch to RCA it’s there also albeit slightly lower
You have to compare like for like.
Different cables tried on the same input.
Hi @Skeptikal
Unfortunately I am unable to do that has my bluetooth receiver does not have a din socket, as neither does my phonostage.
But, point taken.
Kind regards
Roger.
I guess you could borrow the RCA to DIN lead from your phono stage just to see if it makes any difference on the BT receiver.
