I was listening to my NDS streamer, which is connected to the streamer input on my SN3.
I then accidentally pressed the button marked Tuner and I could still here the streamer, though at a reduced volume.
So I tried all the other inputs and I had the same result.
Is this normal of for the SN3, or indeed any amp?
Thank you.
I’m fairly sure there’s been a thread or two on here about that. I can’t immediately find it, will try and find it/them later. I don’t think it’s unheard of…
It would appear to be the new din lead my dealer has lent me to try. It is a ZenSati Zorro.
Put my Witch Hat one back and all is fine.
I have my bluetooth receiver connected via RCA and that is fine.
Thank you for the responces.
I only experienced today with this loan din lead.
I use a mixture of Din and RCA, on different inputs, and it does not happen with these.
Must be an issue with the loan Din.
I don’t care it’s the connectivity that’s the problem.
And sharing of signals or earths in the path to get there.
The sound difference is not subtle and the surface area connection per conductor is far bigger.
