Klipsch ‘fives’ seems to be the ‘modern world’ budget active speaker that would ‘do the tasks required’… (as would be recommended by a hifi store working friend…)
I’d be keen for whatever bargain (second hand) mini system I could put together…
Probably using a Cambridge ‘the one’ (/Denon/Teac(hi end)/Marantz etc) mini system with a small build.
Other options would be things like the aforementioned (Rega) Brio, but on the second hand market could be anything such as a Quad 303 power amp etc…
My go to mini system over the last couple of years has varied a lot…
I have played with the Cambridge ‘One’, I have bought the Denon micros for friends etc…
I really like the generation one Bowers and Wilkins Zeppelin.
(second hand would fit budget, but I am told the gen ones have a overheat issue (if they’d been driven hard) and can be in need of repair, where as the gen 2 seem to have moved to more of a ‘bi-amp’ (true) situation that seemed to avoid the issues of the first gen units (that I have never experienced myself).
I have, over the years, bought a couple of gen one B&W Zeppelins’.
Fantastic ‘speaker’ that sounds like hifi seperates. (the first gen was nearly 1/3rd more cost that the replacement second gen that reviews said, around the time of release, ‘was better’.)
The included DAC is ‘usable’ (better than what is in the PC), they take 3.5mm input (may need 2xphono/RCA to 3.5mm plug lead), have a fibre optic input (doubles as analogue input), and also have an ancient apple plug, that a $10 adaptor can make a ‘bluetooth receiver’ makin the Zeppelin a very versatile hifi, for peanuts, that sounds really good.
Biggest weakness is ‘size’ (awkward) and inability to seperate the left and right speakers- that being said- these were built knowing their ultimate dimensions and their dispersion is excellent- I seldom have done much more than move a few centimetres from rear walls (in some setups), generally I simply put a large house subwoofer in line to ‘boost the bass’.
I have done PC builds with a Zepp under the monitor, or ‘behind the laptop screen’ etc… and as a ‘nice hifi’ they work, as a ‘nice mini’ they work… asa jack of all trades they work AND they actually have masterful sound quality.
Looks? … ‘eye of the beholder’!
