Where I find version of software?
My NDX 1 is 4.4.0 but I dont know which version 2.9 or 3.0.
Should I update to 4.6 or can I immediately go to 4.8?
You can go to 4.8 directly.
What about version 2.9 and 3.0 ?
It’s explained in your screenshot. If you are on 3.0 or above you can upgrade to 4.8. You are on 4.4, so it’s ok to install 4.8.
Thank you,I am not friendly with IT things .
I understand. It can be a bit scary. Just follow the instructions and take your time.
Maybe wait for new information tomorrow until you do an update since naim will release new version so you don’t have to do it twice in short time
I’ll definitely wait, I also have to buy an RS232 cable and study the instructions
I very much doubt that we will see new firwmare for all first generation players today. I may be wrong but it is unlikely.
Claus
As I understand it the actual sw release was not targeted for today. It was an update from Naim on status and way forward related to this.
Please check the back panel of the NDX. Its user manual shows a mini-USB socket so a USB (A) to USB mini lead is needed, the RS232 cable is probably the wrong one.
On the back side of my NDX is RS232 port no mini USB socket.
I think that is one of the first NDX unit ,serial No is 310…
