I have an old NAP 62 preamp and hicap supply, shoebox sized, plus a power amp of similar vintage that is full width (which infuriatingly I can’t locate at the minute) - I’ve had both for maybe 15-20 years, and have not had them serviced in that time, so they may be due for some fettling.
I don’t especially need another (4th) system but I could give it a home in the study I suppose - am looking for some thoughts. Having the Naim sound would be good but without much cost… and convenience will be key too.
how easy is it to feed it from a streaming source? I can set up a pi with something suitable on and so get rca out so I assume I just need an appropriate rca-din lead, assuming the voltages are ok
is it likely to be worth doing at all - I am assuming it will need refreshing and recapping, and at that cost am I better getting a more modern system with easy convenience - or is the cost of a refresh likely to be surprisingly cheap?
if I sell it am I likely to need to have it serviced first, or is there a market for ‘original’ gear…?
