CI-NAP 108
I recently got the CI-NAP 108 for our surround sound system. It’s replacing two NAP145s, one NAP250, and four-channel Arcam amps.
I kept one NAP145 for the center channel and used the Statement for the front via AV bypass.
I think Naim missed a trick because it’s designed for rack mounting. So, I had to find some feet so I could put it on the Frame.
Now it’s up and running, and the sound is really good. It’s a bit different from the old analog amps, but it’s better suited for cinema use.
I ran it for just over an hour last night at around 95 dB, and the amp case temperature was 34 degrees Celsius. That’s pretty cool, considering it doesn’t have a fan. It just has natural ventilation.
In what aspects would you say it’s different to the NAP145 etc (or say, a more suitable comparison like the old 175, if you ever had one?)….Im not 100% sure, but I think it’s class D amplification yes…?
Were you able to experiment with any EQ/speaker profiling via the App/Manager or is that only with the CI-102…?
I know they’re aiming the range at custom integration and primarily for separate ‘zones’, although there is brief mention of use with Audio-Video processors in the marketing blurb, but you would think they’d push the AV use a bit more prominent…Looks an ideal product for surround sound use…and then you have the NC200 and 350’s for primary channels if desired (or indeed the CI-100, though not sure if this available yet?)……
All we now really need (and I’ve long wanted) is the AV3…!
I’m surprised there is no separate AV processor unit in this new CI range, especially as they’ve built some EQ etc into the CI-102….
SC
p.s. I agree, some included simple stick on feet for the base would have been a good idea…Not everything is rack mounted, even in the CI world….
Yes its class D amplification and has a different sound to the classic range, great for surround, wouldn’t want it for the primary channels
CI-NAP 108 has a dip switch for use without 102 so no access via app, therefore using as 8 independent Amps
The CI range has attracted very little comment on this forum , yet this post as well as the forum member who compared his model to the Atom have both commented very favourably .
Maybe this Class D has something going for it after all.
Time to put on a tin hat, find a foxhole and suck on a jaffa
I did actually inquire about the 108 to my dealer. Possibly the only thing they could have sold me. They said the CI stuff was rather good. When asked what I wanted it for, I said it was for powering the main 7 channels of my ATMOS system and take the load off the Denon AVC6800H. They said, “in that case, don’t bother. The 6800 is brilliant. Save your money.”
My main problem with the CI stuff is that the simple styling looks much better than the New Classic range
I had looked at the 101 as it was 2Ohm capable and when I checked the spec 500W into 8 Ohms, 800 into 4 Ohms, I was interested as I want to move two of my 500W sub amps onto new 15" and add a bit more headroom with the 18’s. they are small and neat, not sure on fan noise as CI but not crazy price for the power and small and neat
Seems odd as it was on there I checked the spec sheet
No longer looking in any case as I have gone old school and found some 1,000W huge mono Mosfet amps for the 18" the transformers make naim 500 amps look modest
Not for me it isn’t….and it was not seeing it the other day that lead me to remark that in my post (#2) questioning whether it was available or not….It’s in the spec sheet/brochure as others have mentioned, but it doesn’t seem to be on the website listed as a individual item….
This is me currently browsing via iPhone Safari….Screen grabs as I scroll down the page….
Apologies. Yes, I see you’re referring to the 101. It’s not on there yet as I don’t think it has been released yet. So far it’s just the 102 and the 108.
Info and Product Sheets can be read and downloaded from this thread:
I would guess that final specs for the CI-NAP 101 won’t be nailed down until it’s given the green light.
Unless I’m missing something, the Naim CI-Uniti 102 Streamer/Amplifier appears to be a remarkable value for money one-box solution, albeit needing remote configuration and management…… but isn’t that what we do anyway?
Yeah…Tyson is showing as 3-4 day delivery….
Whether that’s porkies or not I don’t know, though not really like them…
I also checked at StoneAudio, who are a large custom installer I’ve worked with in the past and have accurate stock levels, but surprisingly no listing for the 101, just the 102 currently….
If it’s not even actually released, shouldn’t really be on the spec sheet and CI brochure until such time it is (especially if as Richard infers the final spec is not locked down)….DVD5 Scaler anyone…?!
I’ve just seen a new communique to Naim’s dealers and distributors. It looks like the CI-NAP108 is now shipping;
The Naim Audio CI SERIES, our range of electronic products perfectly suited to power integrated audio setups, is now shipping globally.
The range comprises three products designed to complement integrated setups and CI Focal loudspeakers.
CI-UNITI 102
The CI-Uniti 102 is a streamer/amplifier that offers both musical performance and versatility. It is designed to seamlessly integrate into any indoor or outdoor space, providing amplification for CI Focal speakers and enhancing audio from all media sources.
CI-NAP 108
The CI-NAP 108 is a rack-mountable 8-channel power amplifier. When paired with the CI-Uniti 102, it enables connection to multiple speakers in different rooms or the amplification of eight separate audio streams.
CI-NAP 101
The CI-NAP 101 is a rack-mountable mono power amplifier capable of operating in low or high-impedance mode. Along with the CI-Uniti 102, it is specifically intended for use with subwoofers or speakers on a 70/100V line while maintaining exceptional audio quality.
This series marks a new era for Naim and Focal , as we now offer complete solutions in the Custom Integration (CI) market for the first time. The products combine Naim’s core DNA with Focal’s expertise in acoustics, catering to home (indoor/outdoor), maritime, and commercial spaces. Offering exceptional performance, versatility and ease of use, the CI Series is designed for music lovers to listen in high fidelity, regardless of environment.
The original launch post with product information can be seen here;
