Hi MpgHarris
Yes, it is a PITA that the CI-102 is not slightly more capable. FYI, I only borrowed the thing for just two weeks last year and I was quickly trying a lot of aspects. In my case I was also building up to a (symmetrically arranged) room that was using loads of acoustic room treatment, so the L/R channel phase imbalance (even at low frequencies) for the main loudspeakers was very small.
Regarding your comment…
I do not believe the implied (audio) professionals (cf ‘home studio types’) to whom you may be referring are the intended market. This is a custom install product for a domestic living space arrangement. The ‘professionals’ in this case are the HiFi retailers using this product to give great sound for customers who want great music experiences in their homes without sitting in environments maxed out with acoustic treatment.
My understanding is that in untreated domestic living spaces there are typically one or two dominant resonances (e.g. sub 50Hz in range 30 Hz to 40 Hz) and their associated low order harmonics as well as a floor to ceiling resonance (e.g. ~72Hz). The ‘stereo’ selection setting for the main outputs would give the capability to appropriately supress the worst offending (‘EQ’ settings applied equally to both L and R) - nevertheless the manual clearly states the overall limitations and the system does not give the ability to apply different EQ for L from R with this ‘stereo’ setting.
FYI, when I was trying to see if I could High Pass roll-on the main loudspeakers (as I had just purchased an active sub bass with two inputs (L and R) and two drivers (which subsequently turned out to be driven always in mono anyway) that’s how it worked for me in my room. I.e. Anything below 100Hz (for example) was delivered in mono and anything above was delivered in stereo.
However, I still think you can do what you wish, but it will need a separate power amplifier or active loudspeakers…
Connect the L amplifier input channel to Speakers/Line output (L).
Connect the R amplifier input channel to Sub/Aux output (R).
Set both Main and Sub preamplifier outputs to Stereo.
Apply NO overall LP or HP separation (i.e. setting ‘OFF’).
Set EQ filters appropriately (parametric or whatever) using the values you have derived for the L channel on Speakers/Line output settings.
Set EQ filters appropriately (parametric or whatever) using the values you have derived for the R channel on Sub/Aux output settings.
Naturally, with the above arrangement you will not be able to use a separate Sub Bass.
Edit PS: Actually one could try to incorporate an active Sub Bass that had two inputs (L and R) that summed to mono internally. The cable would be connected to the ‘unused’ outputs of R on Speaker/Lineout preamplifier output and L on the Sub/Aux preamp output.
The challenge is then to have the SubBass roll off its output seamlessly with the ‘Roll On’ of the Main loudspeakers, based on what they were doing in the room at listening position as a result of their placement in the room.*
The above is quite tricky to do but with REW and a sufficiently controllable Sub Bass should be possible.
