Hi- I just got the Unit Atom and I was wondering if there is anyway to change the time on the clock. It appears to be one hour off- which could be because of daylight savings time here in the US where we set the clocks ahead an hour last week. Any helpful hints, or just live with it?
Go into settings and select a completely different time zone when the Atom elects the time zone go back into settings and reselect your time zone hopefully this should correct the issue.
If the suggestion by @pcd doesn’t help, then it’s possible that another Google Home device in your network is setting the wrong time, which is then picked up by the Atom. The Google enabled devices (for instance containing a Chromecast) all synchronise to the same base time. So you could check if any other Google devices are set to the right time/zone.
