Clock setup for Superuniti
Hi,
I have just acquired a Superuniti and love it. The only challenge is setting up the clock to my current time. I live in the a United States and the clock seems to be configured based on GMT (Greenwich Mean Time). Is there a way to program it for US time? I looked at the “advanced settings” option under the clock settings but found no option explained. Unfortunately the manual states “contact your local naim dealer”. Unfortunately, I didn’t buy it through a dealer.
@naperaudio Is your dealer also a Naim dealer? If so and assuming you purchased other items, they might help you. I also googled and there are several suggestions including AI.
I also have a Superuniti and setting the clock is easy but I am far away from home right now.
Please allow me until tomorrow and I will provide the instructions.
All the best,
Rafael
You have to adjust your time zone, which is under clock settings that you access by pressing the spanner/wrench button on the remote. You can’t do it via the app.
