Following the previous thread on music some random thoughts on kit.
I have spent a few days wandering from room to room listening to kit, and mixing and matching kit to try to understand why my initial upgrade from fc/112/150 to fc/202/200 failed to live up to my expectations. Also why did I hang on to it for so long instead of changing it immediately?
So confirmation after mixing and matching is
the Kans are better than the ls3/5a on any set up.
The Nait2 is better than the 112/150 on the Kans. I also have a ridiculous nostalgic/emotional attachment to this my first Nait system.
The 202/150 is better than the 112/150 on the ls3/5a’s.
The Nait 5i can drive either.
Changing the fc2 for the Supercap makes little difference on the 112/150 into the A5’s
Changing the fc for the Supercap on the 202/200 does make more of a difference on the A5’s.
So conclusion is that 7 years ago
Why didn’t I sell and upgrade to 282 or 252?
I guess at the time I felt that having been disappointed I couldn’t see that another upgrade was going to give me anything that much better again. This hadn’t, so now my expectations were lower.
What I know now is that Naim’s claim to have an upgrade path is true, but not all changes are in fact an upgrade.
The 112/150 and 202/200 are advertised as being capable to run without a separate power supply. Not capable at all imo, they are able to run, but that’s not the same thing at all.
The 112/150 needs a flatcap, the 202/200 needs something better than a flatcap.
Simply put with the benefit of 20/20 hindsight my expectations were too high. That I put down to a combination of Naim marketing, journalistic hyperbole around any new system, and me not trying out all possible combinations that I might have been interested in. When I bought the A5’s originally I tested them against the 112/150 I was going to drive them with. They gave me the sound improvement I wanted over the Kans on the same set up. I didn’t then look at how much better they could be with a system that I didn’t then have.
When I came to the 202/200 I read the reviews and the marketing. I bought the kit and it was an improvement so the journos were right. The 202/200 is an incremental improvement over the 112/150. It just wasn’t WOW.
It now seems to me that there is a definitive hierarchy of matched components to each system level.
FC/112/150
HC/202/200
Napsc/282/200
SC/252/300
Anything else is a temporary interim measure and should be indicated as so. I didn’t understand that, and it isn’t pointed out in any of the reviews or by Naim. Every change is an upgrade seems to be the story, but I found that not to be true.
Which leaves the 250, where does that fit?
I think the overlap is the 200. It just isn’t needed. My fc2/112 in to the 250-2 with the A5’s sounds as good as the fc2/202/200. Why is the 200 needed?
Going up a stage the 250 works well with everything up to the SC/252, and probably beyond.
Of course, none of this is in isolation. I am also driving some A5’s that have only just displayed what they are capable of with the 252 combo. Does this mean I was under driving them? Again the simple answer is yes, but they sounded better than the Kans in a large room with the 112/150, so they were being driven adequately if not at their peak. Similarly, the 202/200 wasn’t that much better than the 112/150.
Looking at it from the other end I compared the Kans on the sc/252/250-2 and they sounded too bright in the larger room. Were they now being over driven? I don’t think so, just they suit a smaller room and the Nait2 or similar (or someone who prefers a brighter, thinner sound).
Of course the burning question now is am I going to be similarly confused with an edge of regret in another 7 years when I make the next leap to a Nap300?
Meanwhile the main room now needs (or I just want) a Stageline and probably a new cart, possibly a better deck, plus a better DAC. More £££££££££££££££
The TV room is woefully underused in that I hardly ever sit in there and listen to music- it’s a TV room with Denon AV kit. The 202/200 is on most of the time as a fill in as we wander from room to room (sqb linking), or with the French doors open as a filler for music outside on a terrace.
Bearing in mind the need for more £££ to be spent and thinking about usage it seems to me the 202/200 could be re homed (and now already has a buyer), the 112/150 can be re homed and is now photographed and boxed up ready to sell on some well known internet site.
That leaves me with the Denon AV as an infill for the TV room, or with the money raised from the sales possibly another Nait 5i in there with the ls3/5a’s.
Also thanks to those that advised on possible areas to upgrade. It’s all been relevant, along with some of the general comments on kit on other threads. I’ve learned a lot in a very short time.
