Note that I don’t forums much, so I apologize in advance if I’m posting in the wrong section…
I’ve been trying to stream through my Uniti Atom Headphone Edition into my Vanatoo T1E powered speakers via the digital COAXIAL input, but after hours of troubleshooting - I can’t seem to get it to work.
I tested the exact same connection through my Bluesound Node and it was an immediate plug-and-play, the cable and speakers worked perfectly through Coaxial.
I tried every input method (digital 1-3, analog etc…), nothing. I also tried changing the headphone input button on the top-left of the Uniti Atom HE to no avail.
Not sure if I’m there’s something I’m overlooking or if there may be a fault with the coaxial port.
I appreciate any feedback, and thank you in advance!
I’m not quite clear on what you’re trying to do - Are you trying to connect the Uniti HE to your Vanatoo speakers via the coaxial digital input on the speakers ? If so, the Uniti HE doesn’t have a digital output.
The Coax and optical sockets on the Atom are inputs, not outputs. They are there so you can add a digital device to the Atom, such as a CD transport etc…
You guys are wonderful, thank you for clarifying that - makes perfect sense now.
Bottom line for me is - it doesn’t look like I’m connecting it directly to my Vanatoo T1E’s
I will however experiment by connecting it to a balanced amp - I might lose the lovely Naim amp sound but it should do the trick well enough.
