Compatibility nsc200 + hicapDR
Hi there
Is it possible to replace in my set up one nd5xs +Preamp XS2 by NSC200 connected to hicapDR being linked to nap200DR
Thanks beforehand for your information
Kind regards
Benoit
Unfortunately the Hicap can’t be used with the NSC222 , but you can use the NSC222 directly with your NAP200 DR.
You’ll need a Signal Lead assembly 4 to do so.
Crystal clear
Benoit
