Connect Roon to NDX2
I have downloaded Roon Labs on my PC Windows - that seems simple. The Roon software picked up my Roskan device but not the NDX2.
How do you make a connection between Roon and NDX2?
Thanks in advance
Is your Roon core and NDX2 on the same subnet of your network. What is your network setup exactly? Also ensure that Roon.exe and RAATServer.exe are exceptions in the Windows firewall.
Sorted. I spoke with Naim. Apparently, the computer needs to recognise the NDX2. By resetting the subnet: https://naim-discourse-files.s3.dualstack.eu-west-2.amazonaws.com/original/3X/f/7/f7880722f155c41f18be0e0f2e6b0c46edf5517d.png
And thanks for the response re network needs to be the same…
