I have a phono stage (pictured) which someone made for me. I haven’t used in a few years because I had nowhere for my turntable (Rega Planar 2) but am setting it up again - and I can’t find the guy who built it.
Trouble is I can’t remember how it all fits together!
I have the two sets of phono leads coming out of the back of box connected to the turntable (pre wired into the turntable) and to the NAC 112 via a 5 pin din.
First problem - there’s no phono channel on the NAC 112 so which channel should I plug it into?
Second problem - I’ve lost the power supply and I assume that would go into the small input in the front of the box (see picture) Is that right?
Since I’ll need to find a power supply any ideas what the likely output of it should be?
Lastly - what’s the 3 pin input on the front of the box for?
